Can't Fill my Fuel Tank - WTF???
I have an 03' cab. V6 CVT.
I went the the gas station to fill up (low fuel light was on and computer said I had 50km to empty) and after adding only 3 litres the fuel nozzle would stop as if the fuel tank was full. Tried it a few more times, and gas actually started to come out as if it was over full, eventhough I had just added a very small amount.
Has this ever happend to anyone else??? I've got 80km to emptynow according to my computer and my nearest dealer is 100km away.
Appreciate any advice. Thanks.
rt69
rt69
will resetting the fuel gauge allow me to fill my tank? Could I have a "kink" or some air trapped in the tank? Is there some kind of security or anti-cyphoning device in the gas tank that has tripped?
Thanks again.
Thanks again.
That SUCKS man! When mine acted up it was right after I had filled up. I was on E (5 miles left), so I filled the car up with almost 16 gallons. When I got back in the car it said I still only had 5 miles left. When I got home I took the battery off for about 2 minutes and when I put it back on the gauge started working again.
try doing what myst said. I work on boats during the summer, and if you've ever heard of the sport wakeboarding the boats are equipped with ballast tanks. The ballast tank has a timer switch. In order to reset the switch so that it will fill all the way instead of just half you have to disconnect the ground wire from the batter for a few minutes and it erases the memory.
