Brake light beeps and flashes when turning.
My brake light in the dash flashes and beeps when turning right. It appears to be more sensative when the temparature is colder. My rotors and pads appear to be fine. I haven't checked the brake fluid, but I would assume the info screen would inform me that is low. Any thoughts or suggestions??
if it is they light that glows red and says 'brake', then it it not the wear sensors. The wear sensors show up as the icon in the DIC. I believe it looks like circle with a squiggly line through it
I have almost the same issue, mine happens just about a minute into driving. Nothing to do with turning. Goes away then comes back little later. I guess I will have to check my brake fluid, and see if that may be the issue. I was going to make an appointment to have it serviced, but Ill give the fluid a check first. If it is that, wonder why its low.
