bad pressure plate?
bad pressure plate?
i just replaced the clutch (oem replacment) and slave cylinder the clutch engaged very low from the floor and i didnt notice till today its back to the top. ive driven about 600 miles since it was replace i drive 300+ a week. is this normal?
lol you know what? i have the same exact problem. i just did the clutch swap and it engages near the floor.
If it was a OEM clutch you put in it should engage at the top of the pedal since that is how it is designed. Maybe when it was engaging at the floor you still had some air in the system causing you to need more travel pedal to disengage the disk complete.
TurboToneNYC
04-30-2013 06:26 PM
