B6 Under Dash Relay Panel
I'm having some issues with the B6 wipers. I have an 03 A4 1.8T and looking for the correct panel relay to replace the wiper relay. I've seen posts regarding panel #6 being the wiper relay, but need to confirm that for the B6's. It cannot be a double relay like the old ones cause there is a plastic piece in-between 5 and 6, and there are no connections for 5. I have a relay 370 - 8D0 951 253 in panel 6. Is this the correct one for the wipers? All my fuses on the side of the dash are intact and not burnt. I still have the motor working and the washer still puts out fluid when I pull back on the stalk. The wipers started acting erratically recently and I've seen posts regarding the motor and transmission. I live in Denver so it's mostly dry, and my baby is garaged (climate controlled) so there is no rust or issues with water getting into the stalks. Can someone confirm which relay is the one for the wipers for me? I'm trying this first before moving under the hood to replace the motor/trans assemblies as the relays are only like $20.
