B6 02 oil filter question
Wrong oil weight
So the local shop I normally take my car to inadvertently put the wrong weight synth oil. They put in 10w30 instead of 5w30 in my '02 A4 with 3.0L. I drove away before noticing on the invoice. It's got 76,000 and the weather in our area is still fairly warm with Fall creeping in. Should I drain and replace, or will I be OK. The manual says 5w30.
Thanks!
Thanks!
Last edited by ColoradoAudiDriver; 08-27-2010 at 11:25 AM. Reason: Different question
It's not a turbo car, so the slightly heavier weight is not a real factor. If it was my car, I would drive it 2-3 months and then when it starts getting cold, change it to a proper weight. BTW, in addition to the 2.7T I also have a 2003 A4 3.0 MT6. The original owner ran dinosaur oil for the first 70k miles and then I switched over to Mobil1 5W-30. The engine is fine.
A4 Jed
06-23-2013 06:13 PM
