Audi a4 avant 2005 s line
Old 08-04-2014 | 03:05 PM
Chapperz83's Avatar
Default Audi a4 avant 2005 s line
Hello people,
i have an issue with my brake pad indicator, im looking for a wiring diagram to find where the plug is that plugs into the loom, can anyone please help me?
Old 08-04-2014 | 08:58 PM
bradtyler02's Avatar
Explain "problem." Problem, as in the light came on? Replace the pads, you'll see the connector.
Problem, as in, you changed the pads and the light won't go out? Could be bad pads, or you have a break in the wire.
Old 08-04-2014 | 08:59 PM
P.S.
Pics of a 2005 A4 Avant S-line are required!
Old 08-05-2014 | 08:08 AM
Chapperz83's Avatar
Default thanks for answering
I've changed the pads and the light won't go out. I've linked the plug on each side with no luck, that's why I nees to find the other end to find which side is broken
Old 08-05-2014 | 09:34 AM
tapsprasad's Avatar
Default This may help you in case of Audi A4 Avant 2005 disc brake
Old 08-06-2014 | 08:57 AM
Ignore the spam^
Your best bet is to probably try and trace the wires back and see if you can find it that way.
Limbatus
S4
06-21-2015 05:20 PM
BITRRBO
07-24-2012 01:52 PM
AudiGuy147
03-26-2012 11:50 AM
jav3323
02-26-2009 05:49 PM
SlineA4
04-22-2008 03:36 PM
Quick Reply: Audi a4 avant 2005 s line
