Audi A4 Avant, 2.5TDI from 2003 suddenly died, and now impossible to start
Old 03-03-2013 | 04:03 PM
perfurt's Avatar
Default Audi A4 Avant, 2.5TDI from 2003 suddenly died, and now impossible to start
Hi all,
Need some expert advice. Last night I was driving approx. 18 kilometers from home, when the engine suddenly died. It refused to start, and I have had it towed home.
Today I bought a new battery (the other one WAS old) and took a readout on VCDS.
Behaviour: Starter cranks, but engine does not fire. All instrument panels lights behaves normally. The remote function for lock/unlock don't work, and I cannot (re)program the remote key anymore, no matter what procedure I follow.
Here's the total readout of the controllers. You can see that the general picture is "too low voltage", but what causes this - can it be immobilizer/ignition switch problems - or something more severe??? Help -I'm clueless at the moment
Address 08: DTCs clearedSunday,03,March,2013,20:06:54:22314
VCDS Version: Release 11.11.5
Data version: 20121222
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
Mileage: 194610km/120925miles
Address 01: Engine Labels: 059-907-401-AKE.clb
Part No: 8E0 907 401 P
Component: 2.5l V6 TDI G000AG 0009
Coding: 02017
Shop #: WSC 63351
VCID: 326101C0FE784B88E78
Subsystem 1 - Part No: 00005059
Component: 130 106JC150_1.V79468425286
WAUZZZ8E33A118394 AUZ6Z0B0209359
1 Fault Found:
01375 - Valves for Engine Mounting; Stage 1
38-10 - Output won't Switch or Short to Plus - Intermittent
Readiness: N/A
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No: 8E3 910 155 G
Component: V30 01J 2.5lTDI RdW 3410
Coding: 00001
Shop #: WSC 04940
VCID: 2C5D1FB8DC5C1D78AD4
1 Fault Found:
18158 - Supply Voltage
P1750 - 35-10 - too Low - Intermittent
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 4529
Coding: 04459
Shop #: WSC 30147
VCID: E5CB2A9C7F366C3032A
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-00 - -
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 J
Component: A4 Klimaautomat 1016
Coding: 00000
Shop #: WSC 63351
VCID: 2855E3A8C8A4315849C
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
27-00 - Implausible Signal
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul NDL 0305
Coding: 00002
Shop #: WSC 00000
VCID: 346D07D8046C45B8F54
3 Faults Found:
01504 - Bulb for License-Plate Light (X)
57-00 - Electric Circuit Failure
01800 - Light Switch (E1)
27-10 - Implausible Signal - Intermittent
00532 - Supply Voltage B+
53-10 - Supply Voltage Too Low - Intermittent
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 B
Component: Airbag 8.4EP 2000
Coding: 0010602
Shop #: WSC 63351 000 00000
VCID: 36693DD0421057A8CB0
1 Fault Found:
002 - Lower Limit Exceeded - Intermittent
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0911
Coding: 01042
Shop #: WSC 00000
VCID: 3E7925F03A209FE8130
2 Faults Found:
01333 - Door Control Module; Rear Left (J388)
49-10 - No Communications - Intermittent
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 930 R
Component: KOMBI+WEGFAHRS. RB4 D35
Coding: 00501
Shop #: WSC 12345
VCID: 36693DD0121057A8CB0
Subsystem 1 - Part No: 18394
Component: AUZ6Z0B0209359
2 Faults Found:
00668 - Supply Voltage Terminal 30
01300 - Control Module for Navigation with CD-Rom (J401)
Address 37: Navigation Labels: 4B0-919-887-BNS4.lbl
Part No: 4B0 919 887 E
Component: BNS 4.2 H05 BNO 0008
VCID: 356B3ADC0F165CB0C2A
1 Fault Found:
65535 - Internal Control Module Memory Error
00-00 - -
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 AT
Component: Komfortgerát T23 1210
Coding: 06976
Shop #: WSC 63351
VCID: 830F14049142B200BCE
Subsystem 1 - Part No: 8E1959801B
Component: Tőrsteuer.FS BRM 0002
Subsystem 2 - Part No: 8E1959802B
Component: Tőrsteuer.BF BRM 0002
Subsystem 3 - Part No: 8E0959801A
Component: Tőrsteuer.HL BRM 0002
Subsystem 4 - Part No: 8E0959802A
Component: Tőrsteuer.HR BRM 0002
6 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
00955 - Key 1
35-00 - -
01331 - Door Control Module; Driver Side (J386)
01332 - Door Control Module; Passenger Side (J387)
01334 - Door Control Module; Rear Right (J389)
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 186
Component: concert II GRO 0008
Coding: 01011
Shop #: WSC 43354
VCID: E4CD3798740C1538254
No fault code found.
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No: 8Z0 919 283 A
Component: Parkingsyst. A4 RDW D07
Coding: 01114
Shop #: WSC 63351
VCID: 438F540451C2F2007CE
End ---------------------------------------------------------------------
iobotic
Audi Q7
08-31-2022 02:55 AM
laalves
B8 Models
06-17-2014 01:58 PM
np1974np
04-06-2012 03:40 PM
AndrewAudi2003A4Quattro
09-05-2011 08:11 PM
pnthr30
10-27-2010 12:49 AM
