Audi A4 2002 3.0 Engine problems
My 2002 a4 3.0 quattro stalled the other day and then started to bog down in low rpms. It occasionally stalls out when it gets under 1k rpms. The ESP turned off and i culdnt turn it back on and the check engine light cam on. I got the readings P0101, P0300, P0172, and P0175. I know the problem can consist of a few things with the MASS air flow censors or the fuel delivery. HAs any one else had a problem like this or maybe know of any commons problems. Any suggestions can help i do not really wanna go spend thousands at the dealership.
Thanks
Thanks
Why are you making so many threads? Just relax and someone will get to you. Posting 3 threads will actually hinder most people from helping you.
Anywho, 16485
P0101
Mass or Volume Air Flow Circ Range/Performance
16684
P0300
Random/Multiple Cylinder Misfire Detected
16556
P0172
Fuel Trim,Bank1 System too Rich
16559
P0175
Fuel Trim,Bank2 System too Rich
From the fault codes it looks like you need a MAF. The MAF sensor is also tied into the ESP system so a faulty maf can cause that too.
Anywho, 16485
P0101
16684
P0300
16556
P0172
16559
P0175
