APR Stage 1 and 1+
Old 04-30-2008, 05:02 PM
bware82's Avatar
Default APR Stage 1 and 1+
i have an 03 1.8t q and i'm looking at getting the APR chip. on the APR website it says that the stage 1+ requires Bosch or APR fuel injectors. does anyone know if it really requires that or would i be okay getting the stage 1+ and then getting larger injectors later?
Old 04-30-2008, 05:23 PM
dahonam's Avatar
SoCal Crew Member
Default RE: APR Stage 1 and 1+
Do not go stage1+ and not have larger injectors... The mapping from stage1 to 1+ is different, it calls for more fuel and more air thus increasing power... It will damage your car... Just go with stage 1 for now, and then upgrade to 1+ later, its free. Also, as far as injectors go, you have more than those 2 choices. Bosch OEM TT225 which are like $350+ for the set, the APR injectors which are even more costly, then you have aftermarket Genesis or Siemens-Deka 380cc injectors which run somewhere in the $250ish range... As mentioned earlier, the upgrade from stage 1 to 1+ is free (on APR's side atleast), but some dealers might charge an "Installation/Reflash" fee.
Old 04-30-2008, 05:53 PM
bware82's Avatar
perfect. that's exactly what i was looking for. i'll go with the stage 1 for now and upgrade to stage 1+ later.
Old 04-30-2008, 06:06 PM
bware82's Avatar
i also forgot to mention my car is TIP. i didn't want it but the wifey did and since happy wife=happy life i had to. but anyways is there anything special i need in order to chip my car other than the chip and injectors for 1.8t TIP?
Old 04-30-2008, 06:16 PM
dahonam's Avatar
SoCal Crew Member
You need an upgraded diverter valve at the least
Old 04-30-2008, 07:07 PM
widgget's Avatar
APR does charge for software upgrades, it's $200 plus shop labor to go to a diffrent APR program. with the labor i paid $260 when i went from Stage 1+ to Stage 2+ (K04 File)
if you go with the Stage 1+ you can get the EFIs for about $300 i think, or pickup a used set for pretty cheap and just install them in the parking lot of the APR dealer before they flash the ECU.
Old 04-30-2008, 07:11 PM
chaos92287's Avatar
you can get away with using the stock valve until it breaks.but there's no telling when that will happen. sometimes its 1 day, others it's months. you need at least a 710n, but id suggest one from Forge.
and you need to regap your plugs or get new ones and gap them to .028
Old 04-30-2008, 07:50 PM
dahonam's Avatar
SoCal Crew Member
ORIGINAL: widgget
Stage 1+ to 2+ is a complete different file, thus they charge. But Stage 1 to 1+ is a slight modification to the file, they DO NOT charge you for it, I know because my shop is an APR dealer.
Old 04-30-2008, 08:11 PM
chaos92287's Avatar
they're still doing the same thing, just reflashing the ECU and adding injectors. some dealers charge for this, others dont
Old 04-30-2008, 11:43 PM
Jimbobdaga's Avatar
Can you install the injectors yourself before getting the flash and then drive like 50 miles to the place you’re going to get your flash done?
Quick Reply: APR Stage 1 and 1+
