Am I doomed??? Vag-Com posted ALOT!!!
Old 05-22-2013 | 03:16 AM
dre.hibnet's Avatar
Exclamation Am I doomed??? Vag-Com posted ALOT!!!
The following is the laundry list of things vag-com reported on Olivia (just bought her so i expected the misfire and temp gauge codes but this is quite a shock)
VAG-COM Version: Release 409.1-US
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01: Engine
Controller: 8E0 909 559 E
Component: 3.0L V6/5V G 0004
Coding: 0016711
Shop #: WSC 63351
13 Faults Found:
17977 - Cruise Control Switch (E45): Implausible Signal
P1569 - 008 - Implausible Signal
19497 - Powertrain Databus Implausible Engine Temp. Message from Inst. Panel
P3041 - 004 - No Signal/Communication
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - Upper Limit Exceeded
16688 - Cylinder 4 Misfire Detected
P0304 - 002 - Lower Limit Exceeded
16687 - Cylinder 3 Misfire Detected
P0303 - 001 - Upper Limit Exceeded
16690 - Cylinder 6 Misfire Detected
P0306 - 002 - Lower Limit Exceeded
16686 - Cylinder 2 Misfire Detected
P0302 - 001 - Upper Limit Exceeded
17538 - Fuel Trim: Bank 2 (Mult): System too Lean
P1130 - 001 - Upper Limit Exceeded - Intermittent
17536 - Fuel Trim: Bank 1 (Mult): System too Lean
P1128 - 001 - Upper Limit Exceeded - Intermittent
16689 - Cylinder 5 Misfire Detected
P0305 - 002 - Lower Limit Exceeded
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 002 - Lower Limit Exceeded - Intermittent
16685 - Cylinder 1 Misfire Detected
P0301 - 002 - Lower Limit Exceeded
16825 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 001 - Upper Limit Exceeded
Readiness: 0000 1001
Address 03: ABS Brakes
Controller: 8E0 614 517 H
Component: ABS/ESP allrad 2328
Coding: 04495
Shop #: WSC 06435
1 Fault Found:
01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30
35-10 - - - Intermittent
Address 08: Auto HVAC
Controller: 8E0 820 043 L
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
1 Fault Found:
00819 - High Pressure Sensor (G65)
07-10 - Signal too Low - Intermittent
Address 09: Cent. Elect.
Controller: 8E0 907 279 E
Component: int. Lastmodul USA 0305
Coding: 00013
Shop #: WSC 63351
No fault code found.
Address 15: Airbags
Controller: 8E0 959 655 C
Component: Airbag 8.4EP 2000
Coding: 0010607
Shop #: WSC 63351
1 Fault Found:
01217 - Side Airbag Igniter: Driver Side (N199)
Address 16: Steering wheel
Controller: 8E0 953 549 N
Component: Lenksáulenmodul 0308
Coding: 02041
Shop #: WSC 63351
3 Faults Found:
01304 - Radio
49-00 - No Communications
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
00895 - Cruise Control Switch (E45)
37-00 - Faulty
Address 17: Instruments
Controller: 8E0 920 950 L
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 03200
2 Faults Found:
01039 - Coolant Temperature Sensor (G2)
30-00 - Open or Short to B+
01304 - Radio
Address 36: Seat Mem. Drvr
Controller: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
Shop #: WSC 63351
2 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
79-00 - Please Check Fault Codes
Address 46: Central Conv.
Controller: 8E0 959 433 BB
Component: Komfortgerát T7B 1311
Coding: 11788
Shop #: WSC 08286
17 Faults Found:
00962 - Alarm via. Tilt Sensor
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01572 - Alarm triggered by Door Contact Switch: Passenger Side
35-00 - -
01574 - Alarm triggered by Door Contact Switch: Right Rear
35-00 - -
01573 - Alarm triggered by Door Contact Switch: Left Rear
35-00 - -
00955 - Key 1
00532 - Supply Voltage B+
37-10 - Faulty - Intermittent
00913 - Window Regulator Switch: Front Right Driver (E81)
27-10 - Implausible Signal - Intermittent
01331 - Door Control Module: Driver Side (J386)
53-10 - Supply Voltage Too Low - Intermittent
01705 - Selection Switch for Mirror-Adjust (E48)
00933 - Electric Window Motor: Passenger Side (V148)
62-10 - No or Incorrect Adjustment - Intermittent
01035 - Electric Window Thermal Protection Active: Passenger
01332 - Door Control Module: Passenger Side (J387)
01562 - Right Rear Door
59-10 - Can't Unlock - Intermittent
Address 55: Xenon Range
Controller: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 63351
1 Fault Found:
01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
End --------------------------------------------------------------------------------------------------
I'm not sure what some of it means exactly, so any help would be GREATLY appreciated! I've been working on figuring this vag-com thing and reading this since 8pm, will check back in the morn to see if anyone has any ideas. Thanks in advance.
Old 05-23-2013 | 01:52 PM
dre.hibnet's Avatar
Default No takers?
I've been looking into the codes and have a few ways to solve the small issues. However i can't seem to get to the bottom of the engine and airbag issues nor the cruise control. Any assistance would be appreciated.
dirttracker
05-19-2011 10:21 PM
b5s4parts
08-24-2010 03:49 AM
5L1K
01-26-2009 09:51 PM
millenia
03-13-2008 01:11 PM
PaulA4
12-22-2004 06:59 PM
