A4 stuck in park, this is some B.S
Old 01-23-2012 | 09:01 PM
paulywalnuts446's Avatar
Default A4 stuck in park, this is some B.S
So to add to the many problems i've had with my b6, i can add one more, so one day my car just decided not to come out of park, i took apart the center of the console where the automatic trans lever is and found a locking mecanisim and manualy pulled it away so i could drive the car, i did some research and people said to change the brake light sensor on the brake pedal, so i did but it did not fix my problem, check the fuse 31 and 14 2 fuses people said to check and they are good, so i just uncliped the magnet sensor that makes it work but i would really like to fix it , ANY IDEas?
-car 2002 a4 1.8t quattro automatic
Old 01-24-2012 | 11:53 AM
also my brake lights work so i know the brake light switch is working ,also the little locking mechanism does work bc it locks and unlocks when i put the key in and out but for some reason its not getting the signal that my foot is on the brake so it wont disengage??? so it has to be somthing inbetween the switch and seloniod????? here are a pic of the little magnet thing that controls the saftey hook, its the little coil thing at the front bottom of the pic above the wire connection...
Old 01-26-2012 | 07:29 PM
bump 1
Old 01-26-2012 | 11:07 PM
02quattrokev's Avatar
Bad tiptroic switch. Get a new one.
Old 01-27-2012 | 09:39 PM
Where is the swith located? By the way my tiptronic works so would it still be that? Also If i do need to change it anyone know a part number or where i can buy it?
Old 01-30-2012 | 09:28 AM
Bump 1
Old 01-30-2012 | 07:15 PM
Audi Tek's Avatar
Tech Certified
The tiptronic switch is the white plastic piece that sits below the chrome trim. Has a connector and a printed circuit board
Does the red foot icon light up and go off on the shift selector when the brake is pressed...?
Old 01-31-2012 | 09:10 AM
NO it doesnt go on and off it just stays On, but i changed the brake light switch and my brake lights work sooo ???
Old 02-03-2012 | 06:53 PM
bump 1
Old 12-22-2018 | 04:01 AM
Racheal Faurie's Avatar
Unhappy Did u Manage with this?
Please let me know if you managed with this. i have exactly the same problem and i've spent like $ 800 trying to fix it already with no luck. (New Shifter & Brake Switch)
I'm in Zambia and we dont have an Audi Dealership so please advise as to how you sorted it out?
green2man0
04-08-2014 02:35 PM
allikat<3
01-25-2014 11:17 PM
Hoguenstein
03-06-2009 01:56 AM
liv2wrshp
10-22-2007 11:43 PM
mcicoria
12-05-2006 04:31 PM
