A4 B6 performance questions...
Hello, I have a 2003 A4 B6 3.0. Am I just dumb or is there just not a lot I can do performance wise? I found a supercharger but it was like 3k. I can't find ram airs, cams, or turbos... Any help would be great! I will say I am going to lower it because it sits way too high!
Like pa4ul said, there's not much you can do to the 3.0L. I'm running into the same problem. But Eibach makes a lowering and anti-sway bar kit. Worth checking out. I have the ST coilovers on mine and they're ok but I want an upgrade. Also, PES-tuning makes a supercharger (which I'm guessing is the one you found) but that's the only force induction system I've found for this engine. However, I did ask a performance gear head about the PES kit, and his response was 137 hp for $4,500 isn't a bad deal
Intake is a waste of money. Check out this video. They do multiple tests with CAI and prove it's just a waste. It is in Kilowatts instead of HP, but you get the idea. (1 KW = 1.35 HP)
