3.0 N80 Valve- Flow
3.0 N80 Valve- Flow
I have a stored code for :
16825 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 002 - Lower Limit Exceeded - Intermittent
Yesterday when filling my gas tank, it would blast out fuel also. I could only fill a small amount at a time without the pressure increasing too much to shut off the pump.
I tested my N80 valve with a multimeter- 26 ohms. When I apply 12vdc, it opens and I can blow through it, although the flow through it is fairly restricted (think blowing through a very small diameter hose)
I have sprayed air intake cleaner through it, the flow does still seem lower than it should be.
So- Is this limited flow through the valve normal? Is my N80 bad? Is the charcoal canister bad?
vtraudt
10-01-2019 08:28 PM
gabeguimaraes
05-22-2009 04:46 PM
