2004 Audi A4 1.8T Engine doesn't start
Here's my problem: the engine doesn't start and I noticed that when I turn on the ignition CHECK lamp doesn't illuminate at all and the ABS light doesn't turn off after 2 seconds as it should (like AIRBAG light). If I disconnect and reconnect the battery, all lights in the instrument cluster illuminates and goes off as it should and then I can start the engine. The bad thing is that after turning the ignition off I can't start the engine and the story begins from the start. Has anyone had the same problem?
Thanks in advance.
Thanks in advance.
Ninam
05-04-2007 05:48 PM
Shizzle
04-07-2007 09:31 PM
