2003 amb a4 1.8t cam cover hose
hi
the attached pic shows a small hose connected to the cam cover. The hose was disconnected and i am not sure how or what is connected to it. I was thinking it had check valve so i put it in with the direction of flow away from the cover.
my question:
does anyone have an accurate diagram as how it is connected?
thanks in advance.
my question:
thanks in advance.
I have the same year A4, that hose runs to the PCV valve running off your breather hose under the intake manifold. That hose does have a check valve, depending on the PCV system your engine has. The older 1.8 has a 19mm PCV. The midyear (my version) uses a PCV with 3 ends and a check valve on that hose. The later 1.8 uses a PCV with a built-in check valve and the hose just runs straight from the VC to it.
thanks
so one with 19mm pcv does not have a check valve if i measure it and it is not 19 then i need a check valve.
if i need a check valve should the flow go to the pcv or to the cam cover?
How do i know if my pcv has a check valve?
Mossyoakglock
09-20-2011 09:14 AM
IOKEPA
06-07-2006 11:17 AM
