2003 3.0 Avant Quattro w/ 55k questions
Hi all - I recently have been having some problems with my car. I had to replace all of my tires due to lack of rotation, obviously that won't be a problem anymore as i rotate all the time. I still feel a bit of rubbing on my front drivers side wheel/tire. When i'm in full lock turning left I definitely feel rubbing, too much rubbing, and when I am on the freeway there is sometimes vibration coming from the front drivers side.
What could cause this? I've been reading that it could be CV stuff or unbalanced wheels. They're audi wheels, but i'm not sure if they're stock on the Quattro...they're 17/225/50.
If they were balance when they were mounted they should be ok. What you might want to check is your alignment. I read a while back a member that had his front subframe come loose, and had similar symptoms; a simple alignmet solved his problem.
2003audiA4avant
05-20-2012 11:24 PM
