'03 A4 Fail Safe Mode
Old 09-24-2011 | 12:19 AM
Mehkai's Avatar
Default '03 A4 Fail Safe Mode
So, my Audi is in fail safe mode, but without any of the symptoms besides my tip mode won't work. I had an issue with the car before, but it wasn't throwing any codes about the tranny, just the coil packs. The car starts in first gear and goes up to fourth, not entirely sure, but I think the tranny isn't shifting to fifth gear. I do alot of around the town driving so I don't really use 5th gear that often. The tranny itself doesn't shift roughly going up in gears, but you can really feel it when it downshifts when I'm stopping at a light or slowing down. Possible theories and solutions?
Old 09-24-2011 | 01:35 AM
Mehkai's Avatar
I have more information. Upon further investigation I have concluded that the fail safe mode only kicks in when I shift to D. I have the sport mode option labeled S and fail safe doesn't kick in when I shift straight to that after starting the car. P, N, R, and S are normal, D brings up limp mode. Sometimes it'll kick back out of safe mode and Tip mode works just fine. D itself works fine and after paying close attention it does shift into 5th gear. Tip shifts into 5th as well, but it's rough, everything else tranny wise works just fine. Resetting the car itself (turning it off and then back on) brings up a normal gear selection display. Only after shifting into D does it go into limp mode. While not urgent, I'd like any opinions that the community may have. Also, is it possible to direct swap a manual tranny in place of an auto? I really hate automatic, it's boring and autos have more issues.
Old 09-27-2011 | 09:12 PM
Dan1969's Avatar
Quattro of FWD?
Old 09-28-2011 | 08:06 PM
Mehkai's Avatar
Quattro
Old 09-28-2011 | 09:12 PM
Dan1969's Avatar
Run a scan on it. I'm sure there's a code in there.
Old 09-29-2011 | 01:40 PM
Mehkai's Avatar
A code for the TCU or the ECM?
Old 09-30-2011 | 11:22 AM
Dan1969's Avatar
For the TCU.
Old 10-01-2011 | 03:29 PM
Mehkai's Avatar
The only place that runs codes for the TCU are dealerships correct?
Old 10-02-2011 | 07:49 PM
Dan1969's Avatar
No. Anyone with a VAGcom tool can help you.
Audiluck
10-14-2013 04:35 PM
blake.m.nelson
04-24-2013 01:25 PM
tonyzp007
11-01-2010 01:41 PM
DLHO
10-08-2007 04:59 PM
MacMurdo
12-15-2005 06:43 PM
Quick Reply: '03 A4 Fail Safe Mode
