Wrong Coolant
Wrong Coolant
Hello all... I could be wrong but let me ask. I just picked up an A4 98 I was checking the fluids and noticed the coolant was low... correct me if i m wrong but the q12 should be used and is red in color.... what s in there now is blue coolant... So until I can flush which would you add q12 or additional blue coolant.
+1. Coolant (aka anti-freeze) is to keep the water from freezing in cold temps. If it's not gonna freeze then you have nothing to worry about by adding water. And do a complete flush when you get a chance and fill it up with G12.
ive never heard of a blue coolant. do not mix coolants! i did an experiment on this and it is not good. if you mix coolant A and coolant B, the performance of the mixture is worse then either A or B separately. if you need to top it off for now, put some distilled water in there as suggested.
http://www.audizine.com/forum/showthread.php?p=3368468
Cioffie
05-19-2013 10:24 PM
ltom76
04-29-2013 09:58 PM
