Would a bad CPS cause LIMP Mode?
My car appears to be in LIMP mode, but is only throwing a "Camshaft Position Sensor: Short or Open to Plus" code in VAG-Com... Would a bad CPS normally cause limp mode? I am awaiting the arrival of the "special order only" part from the VW/Audi Dealer, but I am worried it might be something more...
RE: Would a bad CPS cause LIMP Mode?
Well if the ECM doesn't know exactly when to fire the plugs its not gonna develop any boost.
Give the wiring a quick visual and make sure the connector to the sensor isn't messed up. If it looks ok replace the sensor. Un-less you did a timing belt recently?
Well the cam sensor is right on the front of the cylinder head next to the valve cover gasket. You might have gotten a little oil on the sensor, im not sure if that would mess it up for certain, but i would take it off and clean it just to try it. Spray some brake cleaner on it.
Already took it off and cleaned it and no change... The new one should be here today and I will get it on this evening.
What are the chances that the car could've jumped time? Would that cause a MIL?
Yep there is a possiblity, and thats actually a better chance than the sensor being bad. The last 3 people i helped with cam sensor fault codes happened to be a loose timing belt. So pop off the upper cover and see if there is any slack in the belt. The rule of thumb is you shouldn't be able to twist the belt 90*, pretty tight.
