windsheild washer fluid warning
Thanks for the info suppose then that I should start looking for a new pump,
Does the fluid leak out immediately after you fill the tank up?
If yes, its likely the pump in that diagram. Very common problem and, due to the variety of pumps Audi used, annoying to fix. I just took mine out and plugged up the hole.
If the fluid doesn't leak out, its probably the washer fluid level sensor and/or the related wiring.
My 2.8 has two pumps -- one for the windshield washer (works fine) and one for the headlight washer. The headlight pump was split open and totally rusted out. Any time I added fluid it would all leak out.
I just deleted the headlight pump by plugging the hole and zip tying the wiring out of the way.
I don't get a windshield washer light because I think I turned it off with vag-com a while back.
edit: turning the light off using vag-com I mean,
I've got a 2009 B8 which seems to have the same problem.
It's under warranty, but Audi reckon they don't know how to fix this. They say unless they can identify a fault during testing they can't simply replace a part under warranty.
Is that correct?
Is that correct?
I had this problem too.
Issue 1: Headlight Washer pump rusted and leaking
Issue 2: Reservoir was cracked and leaking.
Replaced the washer pump. And repaired the bottle using JB Weld epoxy.
Epoxy did not fix the leak and is still leaking, the water stays to the level below the water sensor, causing the Washer Fluid warning to go off. With the annoying beep.
FIX: I might replace the bottle in the future, but to fix the warning/beep for now, I just used a 1K Resistor from the local radioshack and inserted in to the sensor wire connectors. (between the 2 wire terminals).
This actually tricks the ECU to think that the Sensor is not open and the water level is OK.
