Why would a company make a product for a car that doesn't fit!!
RANT!!
Maybe I am an idiot. Maybe I am blind.
But how does a company make a product for a car that doesn't fit??
I am talking about the Precision Interface Electronics Auxiliary input for the Audi A4 B5. What this product is "supposed" to do is it would attach to a 13-pin male connector which is normally attached to the 6 disk CD changer. You would unhook this connector from the changer thus rendering the changer useless and you would plug it into a wire that comes with the product into the auxillary unit. From there, you would run a RCA male cable to the front seats and plug it into your phone.
The issue is that there is no 13 pin connector in the trunk!!!
In the 30 minute process this took outside in the bitter Chicago cold, I first unscrewed the plastic mold thats in the trunk that helps hold the carpet wall on the left side. I popped out the carpet wall and tediously unscrewed the bolts which were very hard to reach. I take out the bracket that is holding the CD changer and I come to find that there is no 13-pin connector in existence!
Now even if there was a connector, that whole process is very tedious and annoying just to get the auxiliary unit in and I am very unhappy about this! You can't simply take the changer out with a couple of screws, you have to take out the whole bracket.
Someone please tell I am wrong and an idiot.
i was at the junk yard and seen 2, if not 3 different types of plugs for the disk changer.
i know one is round.(in my 2000, and seems to be in all facelift?)
also there is a rectangular, prolly 13pin connector.
so ur saying the connecotoryou have is round?
but the CD changer doesn't have a connector that IS round?
if that's what u mean, then u have the OTHER style connector, the rectangular one.
otherwise from what i understand, u mean your round connector is NOT 13pin?(the one connected to the CD)
The auxiliary unit that I ordered come with a 13-pin female cable that plugs in the the unit.
The CD changer in the trunk has no 13-pin male cable whatsoever.
The product I purchased is made exactly for my car and sound system.
Are you sure that this cable isn't supposed to be connected to the head unit, bypassing the CD changer and using it's circuit? That's how I hooked up my Sirius Satellite Radio. I'm using a Blitzsafe adapter that taps into the head unit.
What cable is connected to the CD Changer already installed? Are you saying that the CD Changer is not even connected? Was there even a cable connected to it when you removed the changer? If you unplugged the changer, can you take a picture of the connector going to the deck and any connectors in the cavity when the unit is removed? I think pictures would help out out a lot.
If there was no cable running back to changer I would also remove the head unit and see if the CD Changer portion of the connector is wired up. It's the portion of the 20 pin connector circled on the left in the picture below. If it is wired up, you will have to find out where those wires go because they have to end somewhere. Maybe your cable is sitting under the rear seat but you need to confirm if they were wired from the factory or not.
Doug
Doug
