Who has a Bently manual, Haynes, Elsa?
Anyone have a shop manual that tells how to remove the gas tank on a fwd A4?
I've lost my Bently cd, and Elsawin was lost 2 OS reinstalls ago.
Sure thing man. Rather than upload the whole 50 page pdf someplace i just took a screen shot of the diagram:
And the accompanying notes:
1.Return line from engine
-Mark before removing
-Note direction of arrow on connecting flange
2. 20Nm
3. Fuel Filter; arrow points in flow direction
4. Holding clamp for fuel filter
5. Supply line to fuel filter
6. Mounting screw
-25Nm
7. Washer
8. Overflow hose
9. Rubber cap
10. Locking ring
11. Sealing ring-replace if damaged
12. Cover
13. Ground connection
-Connect wiring terminal with mounting screw (item 6)
-After installing, check continuity between metal ring on filler neck and bare chassis ground point. Spec: approx 0 (zero) ohms.
14. Bleed line to EVAP canister
15. Fuel tank
16. 25Nm
17. Bracket for clamp bands
18. Clamp bands - note different lengths and install direction
Also when i was reading through this I ended up finding the tank removal/installation instructions. They're pretty long with more diagrams if you want me to actually upload those someplace for ya. Hope this helps!
2. 20Nm
6. Mounting screw
-25Nm
7. Washer
8. Overflow hose
9. Rubber cap
10. Locking ring
12. Cover
15. Fuel tank
16. 25Nm
