Whining noise at high rpm when under load
I hope someone can help. I have a 2000 b5 a4 with the 1.8t engine. When I rev the engine past 3500 rpm I hear a whining noise coming from the center of the engine. It only happens when the car is moving and at a lower rpm when the car is on a large hill. I recently changed all the belts, the diverter valve, turbo and all of the vacuum lines. I have no idea what it could be. The mods I have are an APR chip and Apr hoses. If I switch the chip to stock program the noise appears after 5000 rpm.
Any suggestions?
Any suggestions?
I have checked and all of my hoses seem tight. Sadly, no boost gauge. If I get on the throttle there is a slight stutter in the car. Would small leaks in the intercooler hoses cause that noise? If so, I will change the intercdooler hoses and see what happens.
Did you ever replace your diverter valve when you went with APR? That could also cause a leak, but I'm not sure what that leak would sound like. It could also be a random breather hose or check valve. A boost gauge is a very worthwhile investment!
I put in a 710n diverter. I have changed all of the vacuum lines and those check valves. I am thinking of ordering the SAMCO intercooler hoses unless someone has a different recommendation. I should invest in a boost gauge. My car is so mild, I just didn't think it was worth doing.
duxbak99
07-13-2010 10:04 AM
satishtadi
10-30-2006 12:25 AM
