Where should I tap to get power?
I need to tap a power wire that is only hot when the ignition is turned on, and can support my two LED headlamps. I don't feel like wiring a switch all the way inside the car and I don't want to wire it into the headlamps or parking lamps.
Anyone have any suggestions?
These kind of LED's. The low beams are only hot when the light is turned on. Only two wires going to the lows, a ground and hot.
I'll check the fuse box, never noticed it, must be under one of the covers.
Ohhh gotcha. Sorry man, didn't really know what you were gettin at. So you wanna be able to run the LED's completely independent of the low beams right? Just a shot in the dark, but how about the radiator fan lead, that's only hot when the key is on, right?
brettmichaelsmith
04-07-2014 11:00 PM
markhas
02-05-2013 05:50 PM
