where is this relay?
It works well? I'm doing this mod this weekend, just want to make sure it's legit. Did you solder the same # plugs as in the DIY? just to be clear, is that the 2nd, 4th, and 5th sections from the left soldered together in your pic? Thanks.
< 98 is on the cabin side of the fire wall, behind the rest of the fuses. Its kind of a PITA to get too, unless you have midget hands, cause you have to take apart the lower dash section underneath the steerling wheel.
As far as the wiring goes, to the best of my (somewhat limited) knowledge, the connections should be the same.
GL!
GL!
