where can i get stock headlights and fogs?
Old 09-02-2012, 10:13 PM
FishEye's Avatar
Default where can i get stock headlights and fogs?
when i purchased my car the previoius owner decided it was cool to slap some after market one piece black lights on there and take off the stock fogs and put after market ones... oem fogs are like 300 bucks for one side and the oem euro spec one piece lights are like 600 bucks and they dont even fit... mods are required to be done on the fenders... i've been searching the local wrecking yard but theres not many audis there... just lots of beamers and hondas... any help would be appreciated... thanks..
heres a pic of my headlights / fogs for reference... and my buddys m3 and 530i in the background
Old 09-02-2012, 11:22 PM
ImTheDevil's Avatar
Look on eBay for OEM fogs (around $90 although I don't know if they include grilles). For headlights, get the Depo two-piece projectors. I had them before converting to one-piece lights. I will say though that the fender trimming on the one-piece lights is easy and worth doing.
Old 09-02-2012, 11:33 PM
FishEye's Avatar
do you know if i need to do any mods to the wiring for the depo lights?
Old 09-02-2012, 11:34 PM
redline380's Avatar
Legal Moderator
i should be able to sell you fogs and grills if you want. pm me if your interested with exactly what you want
Old 09-03-2012, 03:07 AM
FishEye's Avatar
ima do a little more searching for dismantlers and stuff locally and let u know
Old 09-03-2012, 05:40 AM
kriptonik's Avatar
What Jeremy said. The two piece lights will not require re-wiring.
Also since you have a 97, I believe you didn't have stock fog lights to begin with.
Old 09-03-2012, 07:53 AM
ImTheDevil's Avatar
^^^ exactly. The Depo two-piece lights are made to provide projectors on a pre-facelift car. No fender trimming or rewiring, just plug and play.
Old 09-03-2012, 09:11 PM
FishEye's Avatar
oh ok cool... and where should i get these depo two piece lights? and @kriptonik im not sure if it came with fogs or not but it does have the front fog light switch in the dash... so idk
Old 09-03-2012, 11:35 PM
ImTheDevil's Avatar
The Depo lights are on eBay. You had factory fogs on your car, but what Krip meant was that you didn't have them down low in the bumper. Pre-99.5 cars had them integrated into the bottom center of the headlight assembly.
Old 09-10-2012, 02:13 AM
FishEye's Avatar
ohhhhh ok i got it... the previous owner tapped the fogs i have now into the wiring harness... its the 5 pin connector but theres only actually 4 metal pins the other one is just empty... does that sound right?
Quick Reply: where can i get stock headlights and fogs?
