wheels ???
wheels ???
i just got a set of wheels for free. they are off of a s8 i no they are the same bolt pattern, but are they to wide, there 18x8.5. i going to lower my car after winter also. and what size tires should i run as well thanks
free s8 wheels sounds pretty good.. I also wanna know which ones you're talking about. the only 18" s8 wheels I know of are 18x8 and look identical to b5 s4 wheels but 18" (not the same as b6 s4 wheels)
op, pictures of your car...?
8.5? You'll want 255mm wide or wider. You can go lower than that, like 235, but it'll be easier to scratch the wheels and IMO look like ***. The wider wheels will give you more traction (generally), at least in the dry (snow is often better with skinnies) but they will cost you some gas mileage and stuff due to additional friction. Traction is friction, but friction is also energy lost.
The weight of the car will be spread over a larger contact patch, reducing the PSI at any given point, but still being equal to the mass of the car X gravity.
Skinnier tires are better in the snow because the tire has to plow through less material. The skinnier tires will also be more effective in compact the snow beneath the tire.
AKAUDI
01-29-2015 07:56 AM
eddieau12di
01-11-2013 05:05 PM
OG_35
05-25-2010 12:11 AM
irwins41
08-17-2009 10:41 PM
PlatinumAuto
03-06-2009 12:36 PM
