wheel spacers
wheel spacers
im interested in getting some wheel spacers to get that wide stance look. Id like to get them flush with the fenders and not sure what sizes to get for the front and rear. my rim size is 17x7.5 with 225/45/17 tires. I also dont want to pay a fortune for them since i will need new lugs too im sure.
Where is a good place to get decent spacers? is there much difference between the ones on ebay for 25$ a pair vs ones from tuning sites that cost 50-100 a pair?
also, is this a safe mod to do as long as lugs are proper length?
Thanks in advance
Thanks in advance
What is the offset of your tire? I would stay away from ebay for this just my 2 cents. Pay more from a reputable company. Do you really want the only thing keeping your tire on the car to be something cheap? If you are just want to go flush just messure the distance you need!
1 inche = 25.4 millimeters
so then a 1/4 inch = 6.35
1/2 = 12.7
3/4= 19.05
So there is some rough measurements. So say you have a 1/2 inch to make your tire flush. They wont have a 12.7mm spacer so if the number is less than the 12.7 it will sit inside the fender. If the number is higher it will be poking out a little bit.
1/2 = 12.7
3/4= 19.05
If you want some from a reputable company, buy here: http://shop.achtuning.com/handrdrser...elspacers.aspx
Personally, I wouldn't buy from ebay for this sort of thing...
I would also not go for cheap on something like this, crappy ones can create problems.
many of the hubcentric ebay spacers are good quality. I have the h&r ones that have their own bolts; the spacers bolt onto the hubs and the wheels bolt onto the spacers, so you don't need to buy longer lugs. they're a little bit more money but they're nice to have especially if you want to switch wheels then you don't need all different lug bolts..
most people with spacers have the rear spaced out, it's fine to do.. I have 20mm in the rear and no spacers up front
