Wheel offset/ spacer question
Old 06-21-2012 | 11:53 PM
Christopher Nemitz's Avatar
Default Wheel offset/ spacer question
I have been driving around with 17" rims off a a3 which i believe have a 56mm offset. I read that our cars factory wheel offset is 35mm. The widest tire i could put on without rubbing was a 205/50/17 Using simple math i see it s a 21mm difference. My question is i am planning on lowering my car, and i want to run 235/"please fill in"/17's with a "please fill in"mm spacer. I want as wide of stance as possible without rubbing. Thank you in advance!
Old 06-22-2012 | 10:30 AM
mtroxel's Avatar
No, the stock wheels are 45mm offset. Keep in mind, the farther away you get from that offset, the more leverage you put on the wheel bearings. And if we know anything about B5's, the rear wheel bearings don't need any extra wear and tear.
Old 06-22-2012 | 11:11 AM
kriptonik's Avatar
If you want low offset, you won't be able to run wide tires.
AvantSLine
04-04-2012 09:26 AM
octechgeek
11-16-2008 05:18 PM
Flip
06-17-2008 10:18 AM
AudiOso
05-14-2008 06:07 PM
dc878mmm
03-18-2008 03:21 PM
Quick Reply: Wheel offset/ spacer question
