whats wrong with my car>???
come on guys help me out i need to figure this out and i dont want to drive it so if i dont fine out im gonna tow it to a shop. the noise is coming from the middle of the engine bay right behind the motor its like a wierd grinding noise. i jaked it up yesterday but still couldnt see anything. there was alot of oil leaking but my motor oil is still full. is that gear oil or trany oil. i jsut need some ideas of what to look for. thanks much
RE: whats wrong with my car>???
bump
what do you mean it was coming from the washer fluid? Did it only make the noise when the sprayers were going?
it might be a wheel bearing if you can only hear it when the car is moving but since you said it's coming from the middle of the engine compartment and theres fluid leaking, your transmission might have blown up or you busted some teeth off your gears or something
yeah nevermnd the first box its not coming from the washer fluid area its coming from the middle like i said and it only makes the grind when i rev it even in neutral so i dont think its the gears and it shifts fine
