Whats this Airbag Code Mean?
Address 15: Airbags Labels: None
Part No: 8D0 959 655 M
Component: Airbag 7 Audi 0502
Coding: 00104
Shop #: WSC 06335
2 Faults Found:
01217 - Side Airbag Igniter; Driver Side (N199)
32-10 - Resistance too High - Intermittent
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
This is what i got when i pulled the code using my buddy at work's vag-com
is this from the connector under the seat that i read about being loose, or is it something else?
Coding: 00104
Shop #: WSC 06335
2 Faults Found:
oh. yeah i dont dont know what my codes are cuz i was using my friends vag-com and it said there was a chance the airbag system could be damaged if i scaneed them so i didnt. did urs say that too??
try reseting the codes and zip-tie the conector under the seat tight. and see if it comes back...
Here's the giveaway:
That means the connection is open intermittently, which is indicative of a plug that has been pulled slightly apart (open) and then relaxed and regained continuity. 99% it's the under-seat connection. Zip-tie, reset light, and see if it's a fix - it should be.
I was looking for this a while back, cause my light has been on for a while and the day after I fix mine I find info!
Thanks Devil for the Help!
I know i saw a picture somewhere of someone showing this plug and how to zip tie it, but i searched and searched and cant find the picture, can someone point it out for me if you know what im talking about?
thanks
