What seats will fit? going back to stock from aftermarket
Old 12-28-2011 | 11:59 PM
redline329's Avatar
Arrow What seats will fit? going back to stock from aftermarket
I bought my 97 a4 b5 with aftermarket carbon fiber seats and I want to put stock seats back in now to make use of the heated option it came with. I've done some research but have not found the answer I need yet.
First since I have the heated option does that mean I originally had power seats? Which year and model seats will be a direct fit?
Old 12-29-2011 | 08:28 AM
ImTheDevil's Avatar
A 97 should have a power driver seat and a manual passenger seat. Look under the seats you have now. Power seats have dual rails so you would have two front mounting holes. Manual seats have a single center rail with a locking pin on the seat. If you have heater switches on the dash you'll want to get heated seats.
Old 12-29-2011 | 01:07 PM
DOC_DEPALMA's Avatar
My 97 is the way the devil described
Old 01-03-2012 | 02:30 PM
redline329's Avatar
Both front seats have the center single mounting point do they would both be manuals then. Thanks
So any manual heated seats from 97-01 should fit then? How about the s4 seats?
Old 01-03-2012 | 03:14 PM
CCA4's Avatar
S4 seats are all power on both sides, so they won't fit without some modification to add the extra rail
Old 01-04-2012 | 12:04 PM
redline329's Avatar
Awesome thanks for the info
Old 01-04-2012 | 01:50 PM
jonbonesjones's Avatar
Moderator
the mounting points are there, for both. However, they are not threaded for the other application not natural to the car. when i did my interior swap, there were mounting holes for a manual rail it was just not threaded for a bolt.
Old 01-05-2012 | 07:41 PM
ImTheDevil's Avatar
Nice - that'd save the headache of drilling the proper points. The bigger pain in the *** swap would be going power to manual, since the manual seats have a center rail that is absent in a car with power seats. You'd have to weld the damn thing in. Screw that.
raudi28
09-03-2011 11:45 PM
lennyauditt
10-26-2008 11:14 AM
sr_erick
05-11-2008 06:44 PM
jcostello
11-18-2007 11:29 AM
EvilA4
02-12-2006 10:09 PM
Quick Reply: What seats will fit? going back to stock from aftermarket
