what is the potential of the stock turbo?
RE: what is the potential of the stock turbo?
thanks alot for your input.. i was just curious to know the limits of the stock turbo.. now its just about trying to get the budget for the ELIM setup...
my dream is to b faster than Evo's & STI's.. gotta represent Quattro!!!!!!!!!
I think you would run into more reliability problems by pushing stuff to the limits than you would by upgrading it.
Why would you want to push the k03 to the limit, when you could just upgrade everything? Like everyone said, if you stick with good quality parts and DO IT RIGHT, then reliability won't be a problem.
They call them limits for a reason, the closer something gets to it's limit, the more likely it is to break.
ORIGINAL: 01A4B5
well i didnt plan on staying with the stock turbo.. i just wantd to kno for personal reference the limits of the stock turbo..
do u kno anything about the APR Intake manifold or AWE Drive Train Stabilizer? & also do u kno where i can find some high performance control arms? i keep finding the OEM replacement sets & 'slightly better' than OEM sets.. i am interested in upgrading the control arms when i eventually upgrade the whole suspension..
im currently saving up for GIAC ECU chip, H&R Springs, Bilstein Shocks, H&R front/rear sway bars, inlet hose & throttle body hose, & a high-flo cat.. estimated $2500
Depends on what engine you have for a crank, but its a AEG (for a 01+) or ABA (97-2000) and then the rest from qedpower.com. The rods are the same scats and the pistons have the pin moved up to account for the added stroke. Those 3 are about $1k for new rods, pistons and used crank.
#18
ORIGINAL: 01A4B5
and you should get Unitronics instead of GIAC. that way when you switch over to a new turbo, it'll be much cheaper. also don't get an inlet or throttle body hose. those are just for looks. when you go BT you can replace them with hardpipes since you'll be doing an fmic and intake anyways.
#20
ORIGINAL: 01A4B5
your link doesnt work.. can u give me the definite one? & what about the control arms???
i hav the AWM B5 Quattro**
http://www.autospeed.us/store.php?crn=223
