What now ?
Old 04-14-2010 | 11:23 PM
Bolton's Avatar
Default What now ?
Ok just got back form pulling the codes from my 98 a4 2.8q 5v. I also just replaced all the vacuum lines (the one from the fuel pressure regulator was pinched off) my MAF and TB are new.
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Mileage: 142240km/88383miles
Address 01: Engine Labels: 078-907-551-AHA.lbl
Part No: 4D0 907 551 AH
Component: 2.8L V6/5V MOTR HS D02
Coding: 06201
Shop #: WSC 91590
1 Fault Found:
17953 - Throttle Valve Controller: Malfunction
P1545 - 35-00 - -
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
Part No: 8E0 614 111 M
Component: ABS/EDS 5.3 QUATTRO D31
Shop #: BB 24302
No fault code found.
Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
Part No: 8L0 820 043 D
Component: A4 KLIMAVOLLAUTOMAT_D75
Coding: 04160
Shop #: WSC 06335
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 15: Airbags Labels: 8D0-959-655-AI7.lbl
Part No: 8D0 959 655 M
Component: Airbag 7 Audi 0502
Coding: 00104
Shop #: WSC 06335
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 8D0-919-xxx-17.lbl
Part No: 8D0 919 861 E
Component: B5-KOMBIINSTR.UN4 D06
Coding: 02362
Shop #: WSC 19411
Part No: IMMO
Component: IDENTNR: AUZ8Z0W4210506
IMMO-IDENTNR: AUZ8Z0W4210506
1 Fault Found:
00771 - Fuel Level Sensor (G)
29-10 - Short to Ground - Intermittent
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 N
Component: CV-Pump D06
Coding: 16140
Shop #: WSC 06335
5 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01365 - Lock/Unlock Switch; Interior
29-00 - Short to Ground
00991 - Interior Lights
28-00 - Short to Plus
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06335
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 4B0 035 186 A
Component: Radio D02
Coding: 00201
Shop #: WSC 06335
End ---------------------------------------------------------------------
So I cleared the codes, and tried to do a TBA but it came back (0.0) (26.5) (idle) (ADP ERROR) Can someone give me a clue what direction to go next ?
Where does the readiness (0110 1101) come into play ?
Old 04-15-2010 | 01:00 AM
Bolton's Avatar
Anyone have any ideas ? Havin no wheels is gettin me down.
Old 04-15-2010 | 01:01 AM
Dallas09's Avatar
Personally, I wouldnt worry about the ADP error. Early models are supposed to do adaptations with the key left on the on but not running position for a few minutes. I tried to do the same thing on my '99 with a VAG, same thing happened and it threw that code. I adapted it with the key and the code remained but the car ran fine and the code finally went away later.
That readiness thing has to do with emissions testing and stuff, the car is "ready" when you have gone through some driving cycles and the emissions look good.
So all those other codes went away then after you cleared them?
EDIT: And what do you mean by no wheels is it not running?
Old 04-15-2010 | 01:31 AM
Bolton's Avatar
So it shouldnt be an issue to just clear the codes and drive it ? It will start and idle at around 800 rpm but when it gets up to 1200 rpm it starts to bounce. Also really seems to lack power. What do you think ?
Old 04-15-2010 | 01:33 AM
Dallas09's Avatar
Well try adapting it with the key in the ignition switched to on for like 7 minutes or so. Other than that maybe someones got some ideas, I woulda said vac lines and MAF maybe but it sounds like youve already done those...
Old 04-15-2010 | 01:38 AM
Bolton's Avatar
I will give it a try again and see what happens.
Thanks.
Old 04-18-2010 | 01:00 AM
Bolton's Avatar
Smile
Today was a very good day. I was able to get my TB to adapt ! After trying to adapt it with the key in the ignition, wait (30 sec, 4 min, 7 min, ect) and have it not work. Then trying to reset it with the vag com thru the engine / measuring blocks/ enter group 060/ ect.... and not work and giving me "adp error" each time. Finally I tried reset readiness and followed the 18 steps. Step 4 being the adp of the throttle body. Sure as sheat I heared the whearl of the TB I was dreaming of. After that it started up and ran GREAT ! Took it for a drive and it had good throttle response and power like I remembered.
Thanks to NTT5418 for the idea to reset the readiness worked great !
