is this what i can expect from audi?
im not sure which could be the reason but thursday i ran my cars gas tank dry because of a faulty gauge going full and empty and in between, also the day before i got a custom cat back done all the way up to the dual cats.
now after i ran my tank dry i got engine codes, to be expected obviously, cleared them and it was fine, then last night they turned on and it said i have 11 codes but i think most were repeated. codes such as:
p1198
p1199
p0300
and something about a manufacturer malfunction or something like that, i got them cleared, drove a few miles and it came back on. what can this be from?
please help me asap i just bought this friggen thing
BTW i dont seem to have any issues with the car it feels fine i dont feel any hesitation or bucking or anything.
p1198
p1199
p0300
there are no codes pertaining to the radiator whatsoever, whoever gave you that info is wrong. can you post up all the codes you have? it'll give us a better picture of what might be wrong. you probably have fouled out your injectors though, fuel system cleaner will do the trick and seafoam will too
http://wiki.ross-tech.com/index.php/Main_Page
put the codes in the search box, this will give you a better explanation
no the problem is- we need all the codes so that we can figure out which are related and which are just normal things that need attention. also when asking for help, if you took the time to post the code and what the code means (from here
http://www.obd-codes.com/trouble_codes/audi/ , among other places) that is less work for the people helping you, and you will more likely get an answer. il tell you im not going to sit here and search for the definitions of 11 different codes and then figure out whats wrong with some random guys car on the internet.
