What is going on with my cooling system?
Old 01-21-2009 | 12:49 AM
Sick Boy's Avatar
Default What is going on with my cooling system?
so im kinda stumped. i put on a new timing belt kit last weekend and since my coolant gauge never worked i made sure i put the thermostat in. and it still did not work. so then yesterday my coolant temp sensor came in and i put that in and what do you know my gauge still does not work right. it seams every time i cold start my car the coolant gauge will work untill it gets to the normal temp and then it will just drop all the way back to the cool side. my oil temp is up around 200F and the heater still blows hotter then hell so i dont think its the Tstat andi made sure that the sensor is pluged in good. so what the hells going o guys? bad brand new sensor?
Old 01-21-2009 | 12:52 AM
SAudi's Avatar
a bad new sensor would be my guess or an electrical break somewhere, if anything id try to replace the ECt since you can still return as a defective item so it wouldnt hurt to try.
northbranchroad
12-15-2011 09:23 AM
MAN.U.Fan79
12-18-2007 12:08 AM
Hetfield713
11-26-2007 03:24 PM
illinoisa6owner
08-12-2006 01:00 AM
matt
11-15-2005 01:30 AM
