What could cause the Parking Brake light in the dash to not come on....
Old 03-09-2011 | 11:08 AM
junkeravant's Avatar
Default What could cause the Parking Brake light in the dash to not come on....
when the Parking Brake is set? The light comes on when the car is started but goes out even though the Parking Brake handle is up? It is a simple circuit as far as I can see.
Either the switch grounds the light or not...correct? Do these switches fail easily?
Old 03-09-2011 | 11:14 AM
CCA4's Avatar
Bulb could be burned out or covered up. I recall reading a thread a while back about a guy who bought his car from a dealer, only to find a few weeks later that the dealer had taken apart the dash and covered all the idiot lights with electrical tape. (because they were all on )
Apart from that, does the parking brake actually work when you lift the handle up, even though the light doesn't come on?
Old 03-09-2011 | 11:20 AM
Default CCA4 you misread.....the bulb DOES WORK.
it just goes out after the car is started. When the Parking Brake handle is lifted and the rear brakes do engage...the light just does not come on.
I am starting to think the the little trigger switch is shot. But it seems ok.
It is very simple circuit.
Old 03-09-2011 | 11:27 AM
CCA4's Avatar
sorry, misread that first part. Not common for that switch to fail but anything's possible. not a big enough deal to tear apart the center console IMO.
lcarunun
12-15-2010 07:19 AM
5th_year_senior
11-08-2009 02:11 PM
audis4v6biturbo
03-09-2008 09:53 PM
mxjess
01-26-2007 04:32 PM
psx2dude
06-15-2006 11:04 PM
