What Brake Pads Is Everyone Using?
gonna have to look into the Hawk HPS pads for my next change then......anyone running the A8 upgrade with these? Any difference between other pads you may have used prior? I have no issue with the pads I'm running now, but if it can be better with a little less dust.....
don't want to threadjack......
Yep, I'm running Hawk HPS with drilled/slotted A8 brakes. I bought them all at one time so I haven't tried other pads with them but I doubt I will. The combination is great and stops right-frigging-now when you hit the pedal. I'd recommend this setup to anybody.
Tell me about it - my inspection is due by the end of May. I have a laundry list too - gotta do front CAs, rear pads and rotors plus one slider bolt, fuel sending unit, outer TREs, and adjust my ebrake cables to get the ebrake functional again. Then I need to find my next set of wheels, paint my roof black, pick up/paint/install my S4 bumper, dial in my rear coilovers, put in a short shifter, finish my suede interior...it never ends. Thankfully
#18
Nobody can recommend the correct pads for you without knowing your driving style... is it a easy DD? do you do hard canyon runs? auto-x? track days? spirited daily? the Hawk HPS pads are a good DD pad, but they're more auto-x and twisties oriented. I'd go with mintex red box pads for a spirited DD.
