well i feel like an idiot...
Old 11-06-2008, 01:36 PM
Jc61990's Avatar
yea i dont have problems with the gauge, i watch it climb up... ill just hold onto it until need it
Old 11-06-2008, 01:42 PM
onepoint8tee's Avatar
Originally Posted by AutoUnionFan
Did you still replace the ECT sensor? If the ECTs is going bad then you should notice issues with your ECT gauge. When my ECTs was going bad, the gauge would be at C after 20mins of driving. Then it would suddenly jump to the middle. I knew it wasnt the thermostat becasue I had recently replaced that. If you dont have any issues, you could hold off on replacing it.
The ects simply relays coolant temp to the ecu so it can make richness corrections. There is a different coolant sensor that is on the raiator which is responsible for what you are talking about, which is hardly ever an issue. It is not technicaly the ENGINE coolant temp sensor because it isn't attatched to the engine, but the radiator.
Old 11-06-2008, 01:51 PM
AutoUnionFan's Avatar
Now im confused. My coolant temp gauge was acting strange. I ordered an ECTs from the dealer (the green one). I installed it, on the back of the engine near the firewall, and the coolant temp gauge began working again. It sounds like you are saying that this sensor is not responsible for the gauge reading or something.
EDIT: I found this link: http://www.audizine.com/forum/showthread.php?t=230355
4bagels states that the sensor is two sensors in one and 4 conductors - two for the gauge and two for the ECU
Old 11-06-2008, 01:59 PM
CCA4's Avatar
JC, don't worry about it man, people do dumb **** it happens. When i first bought my B5, I wanted to see what was under the plastic covers on the engine and air box, so i took them off and in the process, jacked up the wiring coming out of the ICM. That was before I got VAG COM so it took about 5 hours of a mechanic pokin around to figure out that i had accidentally yanked one of the wires out of the plug coming out of the ICM. (DUMBASS!)
Old 11-06-2008, 02:06 PM
That is good information and goes against what my audi tech buddy told me when mine was bad. Maybe what I speak of pertains to 96-99 only since they use a different sensor. Sorry for the confusion and thanks for the info.
Old 11-06-2008, 02:07 PM
Jc61990's Avatar
yea... lol i looked at your sig where it says CAUTION: Quattro kicks *** when wet!.. yes it does.. except it almost killed me 2 times last night.. god damn wet leaves, and awd burnouts are fun.
Old 11-06-2008, 02:13 PM
Yea I though you might be speaking about a different year/variant. And now I learned something new about my car!
mrdeeds23
09-16-2010 06:40 PM
tmic0723
06-01-2010 02:09 PM
Fedaykin
05-17-2009 03:16 PM
fenderstrat1184
05-07-2006 08:36 PM
konvex
01-24-2006 06:41 PM
Quick Reply: well i feel like an idiot...
