Weird Smell..
Old 05-05-2010, 09:22 PM
exequiel3k's Avatar
Default Weird Smell..
Here's the low down..
when I turn On the Climate Control with "Econ" Off.. The car does its job fine without any weird smell coming from the air vents.
When I push the Econ button to ON; there is a weird oily smell coming into the car from the vents, especially when the car is Immobile at a stop light..
Any clues??
Old 05-05-2010, 09:27 PM
turbo kraut's Avatar
Tech Guru
i would change your cabin filter, even if it isn't it, probably needs to be changed, then see if the odor is still there
Old 05-05-2010, 09:44 PM
Tourbo24's Avatar
where is the cabin filter located? i wanted to clean mine LOL
Old 05-05-2010, 09:49 PM
Tech Guru
under the wiper shroud, by the battery, you can't clean it, you have to replace it
exequiel3k's Avatar
I changed it.. it's located at the top-left side under the hood.
Old 05-06-2010, 06:18 PM
exequiel3k's Avatar
No clues anybody??? (o.O)
Old 05-06-2010, 09:26 PM
Tech Guru
it is hard to tell a smell through the net... maybe you need to find someone close or just buck up and have someone tell you what it is
Old 05-06-2010, 09:54 PM
exequiel3k's Avatar
oki, but still.. do you guys have any idea why it would smell Oddly from the vents Only when "Econ Mode" in Climate Control is On?
Isn't it weird??
Old 05-06-2010, 10:25 PM
Tech Guru
spray some smelly good in through the cabin filter area, you probably have some moisture that molded or somethi ng
Old 05-06-2010, 11:08 PM
joenelson7687's Avatar
econ i believe pulls just are from outside. Even though you replaced the filter, you still have those engine vapors that can creep through. Try and run it with the hood up and see if that makes a difference. If it doesn't, then kraut is probably right and you have a science experiment growing in there
Quick Reply: Weird Smell..
