Weird Smell..
Weird Smell..
Here's the low down..
when I turn On the Climate Control with "Econ" Off.. The car does its job fine without any weird smell coming from the air vents.
When I push the Econ button to ON; there is a weird oily smell coming into the car from the vents, especially when the car is Immobile at a stop light..
Any clues??
Any clues??
econ i believe pulls just are from outside. Even though you replaced the filter, you still have those engine vapors that can creep through. Try and run it with the hood up and see if that makes a difference. If it doesn't, then kraut is probably right and you have a science experiment growing in there
