weird HID problem
Old 07-11-2008 | 06:24 PM
Quattro_1.8t's Avatar
Default weird HID problem
I have the McCollich 8000K HID kit, bought new bulbs recently. Only one HID lights up and thats the passenger side. I tampered with the driver side one and i got the bulb to flicker on but it went right off. Any idea whats the problem?
Old 07-11-2008 | 06:53 PM
Tweaked's Avatar
Default RE: weird HID problem
Have you tried swapping the bulbs L to R to see if the problem stays with the light or the bulb?
Old 07-11-2008 | 07:01 PM
no i put in an extra 10000K bulb I have laying around and it didnt power on either
Old 07-11-2008 | 07:09 PM
Tweaked's Avatar
Possibly the ballast if so. I don't know quite how they're installed, but try swapping the ballast L to R.
Old 07-11-2008 | 08:45 PM
Tried swapping them, still only passenger side lights up. Im thinking maybe the 10000K bulb is dead and I need new bulbs?
Old 07-11-2008 | 10:41 PM
Tweaked's Avatar
I thought you said you just recently bought new bulbs? Have you grabbed a DVOM and checked voltage at the bulb socket?
Old 07-11-2008 | 10:44 PM
Tweaked's Avatar
Or try using the bulb you KNOW works to eliminate that possibility.
Old 07-12-2008 | 04:16 PM
will try that thanks
Old 07-12-2008 | 05:38 PM
strudel's Avatar
Just a test.
Old 07-12-2008 | 06:11 PM
sineo's Avatar
Have you swapped the functioning bulb and ballast (one at a time) to the other side yet? That'll narrow down the problem. Could be a fuse...that happened to me recently.
