weird electrical problem
ok, i came from work on friday (today sunday) then i went to visit my fam in my brothers car, when i came back today i start the car it was nomal, i went to the store when i went back to the car it didnt start, like if the battery died, i called my bro to bring the jumper starter, and the car started, i drove home (about 2 miles) i parked and the car died again....
It may be the battery, but if it was parked like 2 days why did it started? could it be the alternator? what else should i check???
Check your battery cables for corrosion. Clean the terminals, top off the water, and charge it to full. Then load test the battery. If it passes, you can then load-test the alternator. If your battery fails a load test, replace it and then check the charging system.
Lights look normal.. i hope is just the battery
ditobot
02-06-2012 10:51 PM
jpcallmotor
07-14-2010 10:00 AM
auditt225
12-19-2008 10:35 AM
