RE: Weaksauce dyno
Uhh... here we go again.
Josh |
RE: Weaksauce dyno
found this over at AW . . . quick search. Not sure of which K03 though, pre 2001 or not? 1. The K03 and K04 use the same castings for the compressor side and the "hot" (exhaust) side. 2. The K03 and the K04 use different compressor turbines. 3. THE K03 AND K04 USE DIFFERENT EXHAUST TURBINES! 4. The shafts are exactly the same. 5. The cartridge (center section) is exactly the same. The original K03 (used in 150hp A4's) had smaller compressor and turbine wheels. The K03-S (Sport, in the 170hp models) utilize the SAME turbine wheel as the K04-15. The difference between the K03-S and K04-15 is that the K04-15 has a more aggressive compressor trim... diameter and A/R should be the same IIRC. This information was based solely with my own experience, back in the days while trying to build up my own ultimate "hybrid" (seeing that the E05 and SK04 were failures). |
RE: Weaksauce dyno
ORIGINAL: pyropenguin
found this over at AW . . . quick search. Not sure of which K03 though, pre 2001 or not? 1. The K03 and K04 use the same castings for the compressor side and the "hot" (exhaust) side. 2. The K03 and the K04 use different compressor turbines. 3. THE K03 AND K04 USE DIFFERENT EXHAUST TURBINES! 4. The shafts are exactly the same. 5. The cartridge (center section) is exactly the same. The AZ stuff is so far off and not worth my time to correct since all the info is above. OK, now for why its a worthless "upgrade" for the 1000th time. You are spending over $1k for basically a larger tq spike that last all of 500-600rpms and maybe 10-15whp. Also what is even more retarted is that people run the turbo to basically 2bar to make the power. The turbo starts falling out of efficiency past 1bar. Just think about that for a bit and you will see why it makes comparing these turbos retarted. You push the ko3 the same way and will get basically the same results w/o spending all the money for the turbo. You want to hold psi longer, buy a mbc and if you still want to hold power, turn the wastegate nut 2 full turns. |
RE: Weaksauce dyno
ORIGINAL: MissionCtrl no its a manual, and those numbers are corrected. but regardless, something is still not right http://www.core77.com/blog/images/image025.jpg |
RE: Weaksauce dyno
lol i love how these things allways happen. I was just saying it can make more power, thats it. i know they are very similar, and i also think that it is a worthless upgrade. Thats it!
RE: Weaksauce dyno
I want twin K03's:D
RE: Weaksauce dyno
ORIGINAL: CLX I want twin K03's :D |
RE: Weaksauce dyno
ORIGINAL: CLX I want twin K03's:D |
RE: Weaksauce dyno
i had mine dynoed and i was at 208, and i dont even know how i got that much, but it was dynoed 3 pulls and it even went to 212awhp, but i was on a dynojet, i dont hae the dyno sheet on this computer b/c i just got this laptop, but i can swear to you that i ran that, maybe something is done to my car that i dont know about, but it was supposedly stock when it was bought
RE: Weaksauce dyno
ORIGINAL: 1.8TK3MP i had mine dynoed and i was at 208, and i dont even know how i got that much, but it was dynoed 3 pulls and it even went to 212awhp, but i was on a dynojet, i dont hae the dyno sheet on this computer b/c i just got this laptop, but i can swear to you that i ran that, maybe something is done to my car that i dont know about, but it was supposedly stock when it was bought Oh, ok, you don't have the dyno sheet, too bad. |
