Water under the hood
Remove the battery from it's mounting bracket,you will see 2 holes with rubber boots,they probably are filled with leaves,weed,cocaine and other debris ,clear it and you should be fine.
when it get clocked up,the water builds up,you better hurry or you're battery compartment will rust and rot away after awhile.
ladybird
12-09-2013 02:45 PM
goodsaxx71
09-14-2010 09:36 AM
kt4406
07-06-2007 10:37 AM
