Water Pump Impeller: Metal vs. Plastic
Ran across this while shopping for a TB kit. Thought it was worth posting for everyone else to see
http://blauparts.com/vw_water_pump_r...ntroversy.html
Thats pretty much what I gathered from all of it. The one thing I *don't* necessarily agree with is the part where he said that it could be detrimental to your engine if you use one or the other and it didn't come with that from the factory. There can't be THAT much difference between them can there?
I think they are trying to give the composites a better name, and by they saying metal is worse... but by how much. sometimes companies say their product is far superior based on a thousandth of a decimal point
PPS pumps are used for one reason, and one reason only....They're cheaper than metal, period.
If they are SO fantastic why is it whenever i take one out of a 1.8T (like the 05 B6 i just did 2 weeks ago) have fins broken off? The one i just took out had three fins broken off.
Its all BS, metal or plastic, the bearings and O-rings won't last more than 100k anyways, so if you ask me i'll take metal any day of the week. I would rather it leak then sending plastic fins into my coolant system that i can't retrieve.
What do you think about what I mentioned earlier? Where the guy said that you shouldn't swap between PPS and metal pumps because your cooling system was "specially designed" to work with one or the other?
