water condensation inside my Angel eye lights!
I noticed a few times,after driving my car,water builds up on the plastic on both right and left lights,is this normal or something i have to address? and if so,how would i go about addressing it?
Bogus oh well..i swapped em for a 9 dollar vag-com USB cable anyway! I would think there is something i could do to atleast reduce the amount of water build up though.
Yup do exactly what Devil said BUT The key is make sure EVERYTHING is completely dry before you seal it. If you seal it with any type of water in there is gonna get nasty. I have seen a few people jump the gun and seal them before they were completely dry and the inside of the headlights looked like a shower that wasn't cleaned for years.
HI DEVIL!!!! LOL
HI DEVIL!!!! LOL
The best thing you can do is put it in your oven on the LOWEST setting that it will do. It is not hot enough to melt the plastic but it hot enough to evaporate the water out. Leave it in there an hour or so and then I would let it stay in there an additional hour or two after you take it out. I would check on it a couple times early on just to make sure that your low setting isn't freakishly hot or something. I use this for electronics that got wet all the time.
they are cheaply made lights so that is why they leak.... you need to dry them and seal the lights..... problem is depending on how cheap they are, just sealing the edges might not be enough.... but don't seal the bulb holes
and to all the hater(haters gonna hate) yes i said noob... yes i called his lights cheap... yes i told him to search or that he should of searched
but it is cause i have seen this question at least 1000 times between this and other forums
