water appears on driver side Audi rubber floor mat after car wash!
![Default](https://www.audiforums.com/forum/images/icons/icon1.gif)
I had the exact same problem. Take out your battery and you will see there is a drain plug located under there aswell as another one under the brake fluid reservoir. If those are clogged water can accumulate in that area and ends up seeping through the holes in the firewall for the wires. I unclogged mine and it fixed everything.
Just make sure that after you reconnect the battery, turn the key to ON but do not start. Let it sit without pressing the gas pedal for about a minute so the throtle body can adapt. You'll have to reset your date/time, and reset your one-touch windows up/down. To do this pull up on the window switch with the windows up.
I took out the battery and just underneath the battery holder thingie,there is a hole with a rubber boot,it was filled with leaves and other foliage,i removed the whole boot,there is another,just like it,to the right,i took out that rubber boot,which was filled with leaves.
I haven't got around to getting a car wash,to find out if this was the cause of the water,draining on my driver side floor but I'm pretty certain,that was the culprit.![Roll Eyes (Sarcastic)](https://www.audiforums.com/forum/images/smilies/rolleyes.gif)
Thanks for the tips guys,i wouldn't have know how to even look for the leak,much less,know how to fix it.![Smile](https://www.audiforums.com/forum/images/smilies/smile.gif)
I'll update you guys,once i give her a bath/shower,she loves when i use bubbles
![Big Grin](https://www.audiforums.com/forum/images/smilies/biggrin.gif)
I'll update you guys,once i give her a bath/shower,she loves when i use bubbles![Big Grin](https://www.audiforums.com/forum/images/smilies/biggrin.gif)
#18
![Thumbs up](https://www.audiforums.com/forum/images/icons/icon14.gif)
The problem with mine actually laid UNDER the windshield cowl. The "T" bracket was torn and allowing water to run UNDER the lower black window trim piece. So, off we go to Audi with an insurance adjustor close behind. The "official cause of damage" was clogged drain plugs under the battery. Off the record, the lower windshield cowl was cracked which allowed water to flow in the fresh air box and then inside car.....For 68 bucks, order on from the dealership and replace it your self. Immediatlt op check it and pour water in the void are to insure the holes are not plugged.
#19
Water still leaks on my driver side rubber Audi floor mat,it is coming from under the steering wheel.
while i was driving home last night from a night club,i felt air on my foot as i was wearing sandles,my air conditioning was off as i looked to make sure it wasn't,i unclogged both drain plugs under my battery and the other drain hold to the right of the one under the battery,its under the brake reservoir ,both was filled with leaves and other foliage.
I was told the take both rubber boots out of the drain holes,all together as to not have it happen again,so i took a pair of needle nose pliers and pulled them both out and i thought i was good to go,wrong!
could anyone help me find the leak?
![Confused](https://www.audiforums.com/forum/images/smilies/confused.gif)
