valve tank ventilation electrical malfunction
Old 06-29-2012 | 03:30 PM
A4driver17's Avatar
Default valve tank ventilation electrical malfunction
Hey guys i had a check engine light and it said p1409 valve tank ventilation electrical malfunction and i was wondering if anyone can tell me what this means? thanks in advance
Old 06-30-2012 | 12:36 PM
setiya_red's Avatar
you need to test the resistance on each injector it should be 12 - 20 omes. you should find at lest one bad injector per side. after you have done this get back with me and we will run a few more tests.
Old 06-30-2012 | 02:18 PM
A4driver17's Avatar
How do i go about checking the resistance? Do i need an ohms meter? and where would i put it to check the resistance? Thank you for the help!
Old 06-30-2012 | 05:15 PM
A4driver17's Avatar
So i tested the fuel injectors and they all read at 17 ohms. Anything else i can do now?
Jfk63
03-23-2011 12:14 PM
BT5150
01-20-2011 11:05 PM
johnblaze
12-13-2006 08:16 PM
V!Link
01-09-2005 11:14 PM
