Valve cover gasket replacement and Camshaft seal (aka Cam adjuster seal)
Old 12-09-2009 | 03:42 AM
Skin_Graft's Avatar
Originally Posted by dragonrage
It is easy to do.... Not as easy as the valve cover gasket, but not much worse.
It should get about an hour of shop time. Actually, I can do it in an hour and I'm not a mechanic. My dad (who was a really good mechanic) used to call me Mr. Slow every time I worked on my cars. $477 is a major ripoff.
I agree... all the quoted estimate says is oil leak found: repl valve cvr gasket, cam ten seal w/ gasket, and cam seal. est $477.
A friend is going to do it all with parts and labor for $100... unless there is more involved when he gets in there.
Old 12-09-2009 | 09:26 AM
dragonrage's Avatar
Oh, wait, cam seal, too? As in the front one? It makes much more sense for that price if so. That's actually cheap (for a dealer, at least0 if so. Are you sure? Make sure it's leaking first. You can pull the upper timing cover and check for oil around the camshaft gear in the front. It's in the upper left.
Annette
02-16-2011 10:48 PM
twinturbosixer
06-07-2009 12:09 AM
xqwizit
11-25-2008 02:22 AM
rib123
09-22-2005 04:34 AM
Quick Reply: Valve cover gasket replacement and Camshaft seal (aka Cam adjuster seal)
